REST API reference
Clear suspect files of a volume
DELETE /security/anti-ransomware/suspects/{volume.uuid}
Introduced In: 9.10
Clears either all the suspect files of a volume or suspect files of a volume based on file format or suspect time provided.
  • security anti-ransomware volume attack clear-suspect
volume.uuid
string
path
True
Identification of the Anti-ransomware suspect file for the deletion.
  • format: uuid
is_false_positive
boolean
query
False
Specifies whether the suspected ransomware activity is a false positive or not.
  • Default value:
file.format
string
query
False
Specifies the file format of the suspect file.
  • Introduced in: 9.18
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
203161673
Operation is not supported on a data protection volume.
203162105
Clearing a suspect by specifying the file format is not supported when an attack is detected by encryption_percentage_analysis.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
