Clear suspect files of a volume
Clears suspect files from a volume, either all at once or based on specified file format or suspect time criteria. This is useful for managing and maintaining the integrity of your storage environment.
HTTP method and endpoint
DELETE /security/anti-ransomware/suspects/{volume.uuid}
Introduced in
ONTAP 9.10
Usage notes
Clears either all the suspect files of a volume or suspect files of a volume based on file format or suspect time provided.
Related ONTAP commands
security anti-ransomware volume attack clear-suspect
volume.uuid |
string |
path |
True |
Identification of the Anti-ransomware suspect file for the deletion.
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
