REST API reference
Clear suspect files of a volume
Clears suspect files from a volume, either all at once or based on specific criteria like file format or suspect time. Use this to manage and maintain the integrity of your storage environment by addressing potential threats.
HTTP method and endpoint
DELETE /security/anti-ransomware/suspects/{volume.uuid}
Introduced in
ONTAP 9.10
Usage notes
Clears either all the suspect files of a volume or suspect files of a volume based on file format or suspect time provided.
  • security anti-ransomware volume attack clear-suspect
volume.uuid
string
path
True
Identification of the Anti-ransomware suspect file for the deletion.
  • format: uuid
is_false_positive
boolean
query
False
Specifies whether the suspected ransomware activity is a false positive or not.
  • Default value:
file.format
string
query
False
Specifies the file format of the suspect file.
  • Introduced in: 9.18
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
203161673
Operation is not supported on a data protection volume.
203162105
Clearing a suspect by specifying the file format is not supported when an attack is detected by encryption_percentage_analysis.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
