Clear suspect files of a volume
Clears suspect files from a volume, either removing all suspect files or targeting specific files based on file format or suspect time.
HTTP method and endpoint
DELETE /security/anti-ransomware/suspects/{volume.uuid}
Introduced in
ONTAP 9.10
Usage notes
Clears either all the suspect files of a volume or suspect files of a volume based on file format or suspect time provided.
Related ONTAP commands
security anti-ransomware volume attack clear-suspect
volume.uuid |
string |
path |
True |
Identification of the Anti-ransomware suspect file for the deletion.
is_false_positive |
boolean |
query |
False |
Specifies whether the suspected ransomware activity is a false positive or not.
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Status: 200, Ok
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: 202, Accepted
