REST API reference
Clear suspect files of a volume
Clears suspect files from a volume, either for all files or based on specific file formats or suspect times. Use this operation when you need to manage or resolve issues with suspect files in your storage volumes.
HTTP method and endpoint
DELETE /security/anti-ransomware/suspects/{volume.uuid}
Introduced in
ONTAP 9.10
Usage notes
Clears either all the suspect files of a volume or suspect files of a volume based on file format or suspect time provided.
  • security anti-ransomware volume attack clear-suspect
volume.uuid
string
path
True
Identification of the Anti-ransomware suspect file for the deletion.
  • format: uuid
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
