REST API reference
Retrieve MetroCluster nodes and configurations
Retrieves the configurations of MetroCluster nodes, which helps you to understand the current state and setup of your MetroCluster environment.
HTTP method and endpoint
GET /cluster/metrocluster/nodes
Introduced in
ONTAP 9.8
Usage notes
Retrieves MetroCluster nodes and their configurations.
  • metrocluster node show
configuration_state
string
query
False
Filter by configuration_state
dr_group_id
integer
query
False
Filter by dr_group_id
automatic_uso
boolean
query
False
Filter by automatic_uso
  • Introduced in: 9.9
node.uuid
string
query
False
Filter by node.uuid
node.name
string
query
False
Filter by node.name
cluster.name
string
query
False
Filter by cluster.name
cluster.uuid
string
query
False
Filter by cluster.uuid
dr_operation_state
string
query
False
Filter by dr_operation_state
dr_mirroring_state
string
query
False
Filter by dr_mirroring_state
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[metrocluster_node]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "cluster": {
        "name": "cluster1",
      "configuration_state": "string",
      "dr_group_id": 0,
      "dr_mirroring_state": "string",
      "dr_operation_state": "string",
      "node": {
        "name": "node1",
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
cluster
_links
_links
name
string
uuid
string
node
_links
_links
name
string
uuid
string
metrocluster_node
Data for a node in a MetroCluster. REST: /api/cluster/metrocluster/nodes
_links
self_link
automatic_uso
boolean
Specifies if automatic unplanned switchover is enabled.
cluster
cluster
configuration_state
string
Configuration state of the node.
dr_group_id
integer
DR Group ID.
dr_mirroring_state
string
State of the DR mirroring configuration.
dr_operation_state
string
State of the DR operation.
node
node
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
