Retrieve MetroCluster nodes and configurations
Accesses MetroCluster nodes and their configurations, helping you understand the current setup and status of your MetroCluster environment.
HTTP method and endpoint
GET /cluster/metrocluster/nodes
Introduced in
ONTAP 9.8
Usage notes
Retrieves MetroCluster nodes and their configurations.
Related ONTAP Commands
metrocluster node show
Learn more
automatic_uso |
boolean |
query |
False |
Filter by automatic_uso
dr_operation_state |
string |
query |
False |
Filter by dr_operation_state
ha_partner_cluster.name |
string |
query |
False |
Filter by ha_partner_cluster.name
ha_partner_cluster.uuid |
string |
query |
False |
Filter by ha_partner_cluster.uuid
dr_group_id |
integer |
query |
False |
Filter by dr_group_id |
limit_enforcement |
string |
query |
False |
Filter by limit_enforcement
dr_partner_cluster.name |
string |
query |
False |
Filter by dr_partner_cluster.name
dr_partner_cluster.uuid |
string |
query |
False |
Filter by dr_partner_cluster.uuid
dr_mirroring_state |
string |
query |
False |
Filter by dr_mirroring_state |
encryption_enabled |
boolean |
query |
False |
Filter by encryption_enabled
ha_partner.uuid |
string |
query |
False |
Filter by ha_partner.uuid
ha_partner.name |
string |
query |
False |
Filter by ha_partner.name
ha_partner.system_id |
string |
query |
False |
Filter by ha_partner.system_id
dr_auxiliary_cluster.name |
string |
query |
False |
Filter by dr_auxiliary_cluster.name
dr_auxiliary_cluster.uuid |
string |
query |
False |
Filter by dr_auxiliary_cluster.uuid
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
node.system_id |
string |
query |
False |
Filter by node.system_id
configuration_state |
string |
query |
False |
Filter by configuration_state |
is_mccip |
boolean |
query |
False |
Filter by is_mccip
cluster.name |
string |
query |
False |
Filter by cluster.name |
cluster.uuid |
string |
query |
False |
Filter by cluster.uuid |
dr_partner.uuid |
string |
query |
False |
Filter by dr_partner.uuid
dr_partner.name |
string |
query |
False |
Filter by dr_partner.name
dr_partner.system_id |
string |
query |
False |
Filter by dr_partner.system_id
dr_auxiliary_partner.uuid |
string |
query |
False |
Filter by dr_auxiliary_partner.uuid
dr_auxiliary_partner.name |
string |
query |
False |
Filter by dr_auxiliary_partner.name
dr_auxiliary_partner.system_id |
string |
query |
False |
Filter by dr_auxiliary_partner.system_id
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[metrocluster_node] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"cluster": {
"name": "cluster1",
"configuration_state": "string",
"dr_auxiliary_cluster": {
"name": "cluster1",
"dr_auxiliary_partner": {
"name": "node1",
"system_id": "string",
"dr_group_id": 0,
"dr_mirroring_state": "string",
"dr_operation_state": "string",
"dr_partner": {
"name": "node1",
"dr_partner_cluster": {
"name": "cluster1",
"ha_partner": {
"name": "node1",
"ha_partner_cluster": {
"name": "cluster1",
"limit_enforcement": "string",
"node": {
"name": "node1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
_links
self |
cluster
_links |
name |
string |
uuid |
string |
DR AUX cluster.
_links |
name |
string |
uuid |
string |
AUX partner node.
_links |
name |
string |
system_id |
string |
uuid |
string |
dr_partner
DR partner node.
_links |
name |
string |
system_id |
string |
uuid |
string |
dr_partner_cluster
DR partner cluster.
_links |
name |
string |
uuid |
string |
ha_partner
HA partner node.
_links |
name |
string |
system_id |
string |
uuid |
string |
ha_partner_cluster
HA partner cluster.
_links |
name |
string |
uuid |
string |
node
_links |
name |
string |
system_id |
string |
uuid |
string |
metrocluster_node
Data for a node in a MetroCluster. REST: /api/cluster/metrocluster/nodes
_links |
automatic_uso |
boolean |
Specifies if automatic unplanned switchover is enabled. |
cluster |
string |
Configuration state of the node. |
dr_auxiliary_cluster |
DR AUX cluster. |
dr_auxiliary_partner |
AUX partner node. |
dr_group_id |
integer |
DR Group ID. |
string |
State of the DR mirroring configuration. |
string |
State of the DR operation. |
dr_partner |
DR partner node. |
dr_partner_cluster |
DR partner cluster. |
boolean |
Indicates if the encryption for NVLog and storage traffic is enabled. |
ha_partner |
HA partner node. |
ha_partner_cluster |
HA partner cluster. |
is_mccip |
boolean |
Indicates whether the configuration type is MCC-IP. |
limit_enforcement |
string |
Indicates if the node object limits are enforced. |
node |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
