REST API reference
Retrieve MetroCluster nodes and configurations
GET /cluster/metrocluster/nodes
Introduced In: 9.8
Retrieves MetroCluster nodes and their configurations.
  • metrocluster node show
is_mccip
boolean
query
False
Filter by is_mccip
  • Introduced in: 9.12
dr_group_id
integer
query
False
Filter by dr_group_id
dr_partner.uuid
string
query
False
Filter by dr_partner.uuid
dr_partner.system_id
string
query
False
Filter by dr_partner.system_id
dr_partner.name
string
query
False
Filter by dr_partner.name
dr_mirroring_state
string
query
False
Filter by dr_mirroring_state
ha_partner.uuid
string
query
False
Filter by ha_partner.uuid
ha_partner.system_id
string
query
False
Filter by ha_partner.system_id
ha_partner.name
string
query
False
Filter by ha_partner.name
encryption_enabled
boolean
query
False
Filter by encryption_enabled
  • Introduced in: 9.15
dr_partner_cluster.name
string
query
False
Filter by dr_partner_cluster.name
dr_partner_cluster.uuid
string
query
False
Filter by dr_partner_cluster.uuid
limit_enforcement
string
query
False
Filter by limit_enforcement
configuration_state
string
query
False
Filter by configuration_state
node.uuid
string
query
False
Filter by node.uuid
node.system_id
string
query
False
Filter by node.system_id
node.name
string
query
False
Filter by node.name
dr_auxiliary_partner.uuid
string
query
False
Filter by dr_auxiliary_partner.uuid
dr_auxiliary_partner.system_id
string
query
False
Filter by dr_auxiliary_partner.system_id
dr_auxiliary_partner.name
string
query
False
Filter by dr_auxiliary_partner.name
automatic_uso
boolean
query
False
Filter by automatic_uso
  • Introduced in: 9.9
dr_auxiliary_cluster.name
string
query
False
Filter by dr_auxiliary_cluster.name
dr_auxiliary_cluster.uuid
string
query
False
Filter by dr_auxiliary_cluster.uuid
cluster.name
string
query
False
Filter by cluster.name
cluster.uuid
string
query
False
Filter by cluster.uuid
ha_partner_cluster.name
string
query
False
Filter by ha_partner_cluster.name
ha_partner_cluster.uuid
string
query
False
Filter by ha_partner_cluster.uuid
dr_operation_state
string
query
False
Filter by dr_operation_state
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[metrocluster_node]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "cluster": {
        "name": "cluster1",
      "configuration_state": "string",
      "dr_auxiliary_cluster": {
        "name": "cluster1",
      "dr_auxiliary_partner": {
        "name": "node1",
        "system_id": "string",
      "dr_group_id": 0,
      "dr_mirroring_state": "string",
      "dr_operation_state": "string",
      "dr_partner": {
        "name": "node1",
      "dr_partner_cluster": {
        "name": "cluster1",
      "ha_partner": {
        "name": "node1",
      "ha_partner_cluster": {
        "name": "cluster1",
      "limit_enforcement": "string",
      "node": {
        "name": "node1",
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
cluster
_links
_links
name
string
uuid
string
DR AUX cluster.
_links
_links
name
string
uuid
string
AUX partner node.
_links
self_link
name
string
system_id
string
uuid
string
dr_partner
DR partner node.
_links
self_link
name
string
system_id
string
uuid
string
dr_partner_cluster
DR partner cluster.
_links
_links
name
string
uuid
string
ha_partner
HA partner node.
_links
self_link
name
string
system_id
string
uuid
string
ha_partner_cluster
HA partner cluster.
_links
_links
name
string
uuid
string
node
_links
self_link
name
string
system_id
string
uuid
string
metrocluster_node
Data for a node in a MetroCluster. REST: /api/cluster/metrocluster/nodes
_links
self_link
automatic_uso
boolean
Specifies if automatic unplanned switchover is enabled.
cluster
cluster
configuration_state
string
Configuration state of the node.
DR AUX cluster.
AUX partner node.
dr_group_id
integer
DR Group ID.
dr_mirroring_state
string
State of the DR mirroring configuration.
dr_operation_state
string
State of the DR operation.
dr_partner
dr_partner
DR partner node.
dr_partner_cluster
dr_partner_cluster
DR partner cluster.
encryption_enabled
boolean
Indicates if the encryption for NVLog and storage traffic is enabled.
ha_partner
ha_partner
HA partner node.
ha_partner_cluster
ha_partner_cluster
HA partner cluster.
is_mccip
boolean
Indicates whether the configuration type is MCC-IP.
limit_enforcement
string
Indicates if the node object limits are enforced.
node
node
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
