REST API reference
Retrieve MetroCluster nodes and configurations
Accesses MetroCluster node details and configurations to understand and manage the current setup of your MetroCluster environment.
HTTP method and endpoint
GET /cluster/metrocluster/nodes
Introduced in
ONTAP 9.8
Usage notes
Retrieves MetroCluster nodes and their configurations.
  • metrocluster node show
dr_mirroring_state
string
query
False
Filter by dr_mirroring_state
automatic_uso
boolean
query
False
Filter by automatic_uso
  • Introduced in: 9.9
configuration_state
string
query
False
Filter by configuration_state
dr_group_id
integer
query
False
Filter by dr_group_id
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
dr_operation_state
string
query
False
Filter by dr_operation_state
cluster.name
string
query
False
Filter by cluster.name
cluster.uuid
string
query
False
Filter by cluster.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[metrocluster_node]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "cluster": {
        "name": "cluster1",
      "configuration_state": "string",
      "dr_group_id": 0,
      "dr_mirroring_state": "string",
      "dr_operation_state": "string",
      "node": {
        "name": "node1",
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
cluster
_links
_links
name
string
uuid
string
node
_links
_links
name
string
uuid
string
metrocluster_node
Data for a node in a MetroCluster. REST: /api/cluster/metrocluster/nodes
_links
self_link
automatic_uso
boolean
Specifies if automatic unplanned switchover is enabled.
cluster
cluster
configuration_state
string
Configuration state of the node.
dr_group_id
integer
DR Group ID.
dr_mirroring_state
string
State of the DR mirroring configuration.
dr_operation_state
string
State of the DR operation.
node
node
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
