REST API reference
Retrieve MetroCluster nodes and configurations
Retrieves information about MetroCluster nodes and their configurations to understand the current setup and status of your MetroCluster environment.
HTTP method and endpoint
GET /cluster/metrocluster/nodes
Introduced in
ONTAP 9.8
Usage notes
Retrieves MetroCluster nodes and their configurations.
  • metrocluster node show
dr_auxiliary_cluster.uuid
string
query
False
Filter by dr_auxiliary_cluster.uuid
  • Introduced in: 9.12
dr_auxiliary_cluster.name
string
query
False
Filter by dr_auxiliary_cluster.name
is_mccip
boolean
query
False
Filter by is_mccip
ha_partner.name
string
query
False
Filter by ha_partner.name
ha_partner.uuid
string
query
False
Filter by ha_partner.uuid
ha_partner.system_id
string
query
False
Filter by ha_partner.system_id
ha_partner_cluster.uuid
string
query
False
Filter by ha_partner_cluster.uuid
ha_partner_cluster.name
string
query
False
Filter by ha_partner_cluster.name
limit_enforcement
string
query
False
Filter by limit_enforcement
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
node.system_id
string
query
False
Filter by node.system_id
dr_mirroring_state
string
query
False
Filter by dr_mirroring_state
automatic_uso
boolean
query
False
Filter by automatic_uso
  • Introduced in: 9.9
dr_partner.name
string
query
False
Filter by dr_partner.name
dr_partner.uuid
string
query
False
Filter by dr_partner.uuid
dr_partner.system_id
string
query
False
Filter by dr_partner.system_id
configuration_state
string
query
False
Filter by configuration_state
cluster.uuid
string
query
False
Filter by cluster.uuid
cluster.name
string
query
False
Filter by cluster.name
dr_partner_cluster.uuid
string
query
False
Filter by dr_partner_cluster.uuid
dr_partner_cluster.name
string
query
False
Filter by dr_partner_cluster.name
dr_group_id
integer
query
False
Filter by dr_group_id
dr_auxiliary_partner.name
string
query
False
Filter by dr_auxiliary_partner.name
dr_auxiliary_partner.uuid
string
query
False
Filter by dr_auxiliary_partner.uuid
dr_auxiliary_partner.system_id
string
query
False
Filter by dr_auxiliary_partner.system_id
dr_operation_state
string
query
False
Filter by dr_operation_state
encryption_enabled
boolean
query
False
Filter by encryption_enabled
  • Introduced in: 9.15
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[metrocluster_node]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "cluster": {
        "name": "cluster1",
      "configuration_state": "string",
      "dr_auxiliary_cluster": {
        "name": "cluster1",
      "dr_auxiliary_partner": {
        "name": "node1",
        "system_id": "string",
      "dr_group_id": 0,
      "dr_mirroring_state": "string",
      "dr_operation_state": "string",
      "dr_partner": {
        "name": "node1",
      "dr_partner_cluster": {
        "name": "cluster1",
      "ha_partner": {
        "name": "node1",
      "ha_partner_cluster": {
        "name": "cluster1",
      "limit_enforcement": "string",
      "node": {
        "name": "node1",
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
self
cluster
_links
_links
name
string
uuid
string
DR AUX cluster.
_links
_links
name
string
uuid
string
AUX partner node.
_links
self_link
name
string
system_id
string
uuid
string
dr_partner
DR partner node.
_links
self_link
name
string
system_id
string
uuid
string
dr_partner_cluster
DR partner cluster.
_links
_links
name
string
uuid
string
ha_partner
HA partner node.
_links
self_link
name
string
system_id
string
uuid
string
ha_partner_cluster
HA partner cluster.
_links
_links
name
string
uuid
string
node
_links
self_link
name
string
system_id
string
uuid
string
metrocluster_node
Data for a node in a MetroCluster. REST: /api/cluster/metrocluster/nodes
_links
self_link
automatic_uso
boolean
Specifies if automatic unplanned switchover is enabled.
cluster
cluster
configuration_state
string
Configuration state of the node.
DR AUX cluster.
AUX partner node.
dr_group_id
integer
DR Group ID.
dr_mirroring_state
string
State of the DR mirroring configuration.
dr_operation_state
string
State of the DR operation.
dr_partner
dr_partner
DR partner node.
dr_partner_cluster
dr_partner_cluster
DR partner cluster.
encryption_enabled
boolean
Indicates if the encryption for NVLog and storage traffic is enabled.
ha_partner
ha_partner
HA partner node.
ha_partner_cluster
ha_partner_cluster
HA partner cluster.
is_mccip
boolean
Indicates whether the configuration type is MCC-IP.
limit_enforcement
string
Indicates if the node object limits are enforced.
node
node
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
