Retrieve MetroCluster nodes and configurations
Retrieves the nodes and their configurations for a MetroCluster, which helps you understand the current setup and status of the MetroCluster environment.
HTTP method and endpoint
GET /cluster/metrocluster/nodes
Introduced in
ONTAP 9.8
Usage notes
Retrieves MetroCluster nodes and their configurations.
Related ONTAP Commands
metrocluster node show
Learn more
automatic_uso |
boolean |
query |
False |
Filter by automatic_uso
configuration_state |
string |
query |
False |
Filter by configuration_state |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
dr_group_id |
integer |
query |
False |
Filter by dr_group_id |
cluster.name |
string |
query |
False |
Filter by cluster.name |
cluster.uuid |
string |
query |
False |
Filter by cluster.uuid |
dr_operation_state |
string |
query |
False |
Filter by dr_operation_state
dr_mirroring_state |
string |
query |
False |
Filter by dr_mirroring_state |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[metrocluster_node] |
"next": {
"href": "/api/resourcelink"
"records": [
"cluster": {
"name": "cluster1",
"configuration_state": "string",
"dr_group_id": 0,
"dr_mirroring_state": "string",
"dr_operation_state": "string",
"node": {
"name": "node1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
_links
self |
cluster
_links |
name |
string |
uuid |
string |
node
_links |
name |
string |
uuid |
string |
metrocluster_node
Data for a node in a MetroCluster. REST: /api/cluster/metrocluster/nodes
_links |
automatic_uso |
boolean |
Specifies if automatic unplanned switchover is enabled. |
cluster |
string |
Configuration state of the node. |
dr_group_id |
integer |
DR Group ID. |
string |
State of the DR mirroring configuration. |
string |
State of the DR operation. |
node |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
