REST API reference
Update the SnapLock retention time of a file
Updates the SnapLock retention time for a file, adjusting the duration a file remains protected under Write Once, Read Many (WORM) compliance. Use this endpoint when you need to modify or extend the retention period to meet specific data governance requirements.
HTTP method and endpoint
PATCH /storage/snaplock/file/{volume.uuid}/{path}
Introduced in
ONTAP 9.7
Usage notes
Updates the SnapLock retention time of a file or extends the retention time of a WORM file. Input parameter "expiry_time" expects the date in ISO 8601 format, "infinite", or "unspecified".
  • volume file retention set
volume.uuid
string
path
True
Volume UUID
path
string
path
True
Path of the file in the form "/<dirpath>/<filename>"
Request Body
Name Type Description
expiry_time
string
Expiry time of the file in date-time format, "infinite", "indefinite", or "unspecified". An "infinite" retention time indicates that the file will be retained forever. An "unspecified" retention time indicates that the file will be retained forever; however, the retention time of the file can be changed to an absolute value. An "indefinite" retention time indicates that the file is under Legal-Hold.
Example request
  "expiry_time": "2058-06-04T19:00:00Z"
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code Description
14090347
File path must be in the format "/
14090348
Invalid Expiry time
string
svm
name
string
The name of the SVM.
uuid
string
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
snaplock_file_retention
expiry_time
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
