Update the SnapLock retention time of a file
Updates the SnapLock retention time of a file to manage the retention period for Write Once, Read Many (WORM) files effectively. This operation is typically used to ensure compliance with data governance policies by extending or modifying file retention as needed.
HTTP method and endpoint
PATCH /storage/snaplock/file/{volume.uuid}/{path}
Introduced in
ONTAP 9.7
Usage notes
Updates the SnapLock retention time of a file or extends the retention time of a WORM file. Input parameter "expiry_time" expects the date in ISO 8601 format, "infinite", or "unspecified".
Related ONTAP commands
volume file retention set
volume.uuid |
string |
path |
True |
Volume UUID |
path |
string |
path |
True |
Path of the file in the form "/<dirpath>/<filename>" |
Request Body
| Name | Type | Description |
expiry_time |
string |
Expiry time of the file in date-time format, "infinite", "indefinite", or "unspecified". An "infinite" retention time indicates that the file will be retained forever. An "unspecified" retention time indicates that the file will be retained forever; however, the retention time of the file can be changed to an absolute value. An "indefinite" retention time indicates that the file is under Legal-Hold. |
Example request
"expiry_time": "2058-06-04 19:00:00 +0000"
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090347 |
File path must be in the format "/ |
14090348 |
Invalid Expiry time |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
volume
name |
string |
The name of the volume. |
uuid |
string |
snaplock_file_retention
expiry_time |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
