REST API reference
Update the SnapLock retention time of a file
PATCH /storage/snaplock/file/{volume.uuid}/{path}
Introduced In: 9.7
Updates the SnapLock retention time of a file or extends the retention time of a WORM file. Input parameters "expiry_time" or "retention_period" can be used to set or extend the retention time of file. Both "expiry_time" and "retention_period" parameters expect the date in ISO 8601 format. Additionally, the "expiry_time" parameter can also be set to "infinite" or "unspecified" and the "retention_period" parameter can also be set to "infinite". The input parameters are mutually exclusive.
  • volume file retention set
volume.uuid
string
path
True
Volume UUID
path
string
path
True
Path of the file in the form "/<dirpath>/<filename>"
Request Body
Name Type Description
expiry_time
string
Expiry time of the file in date-time format, "infinite", "indefinite", or "unspecified". An "infinite" retention time indicates that the file will be retained forever. An "unspecified" retention time indicates that the file will be retained forever; however, the retention time of the file can be changed to an absolute value. An "indefinite" retention time indicates that the file is under Legal-Hold.
is_expired
boolean
This indicates if the file is under active retention or if the file is past its expiry time.
retention_period
string
Duration of retention time file to be locked with, An "infinite" retention period indicates that the file will be retained forever.
seconds_until_expiry
integer
Specifies the number of seconds until the expiration time of the file.
Example request
  "expiry_time": "2058-06-04 19:00:00 +0000",
  "is_expired": 1,
  "retention_period": "P2M",
  "seconds_until_expiry": 168
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code Description
262179
Unexpected argument "\"
262186
Field "expiry_time" cannot be used with field "retention_period"
6691623
User is not authorized
13763279
The resulting expiry time due to the specified retention period is earlier than the current expiry time
14090348
Invalid Expiry time
14090347
File path must be in the format "\/<dir>\/<file path>"
917804
Path should be given in the format "\/\vol\/<volume name>\/<file path>".
string
svm
name
string
uuid
string
volume
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
snaplock_file_retention
expiry_time
string
is_expired
boolean
retention_period
string
integer
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
