REST API reference
Update the SnapLock retention time of a file
Updates the SnapLock retention time of a file to manage or extend the retention period for Write Once, Read Many (WORM) files. Use this endpoint to specify or change the expiration settings for file retention.
HTTP method and endpoint
PATCH /storage/snaplock/file/{volume.uuid}/{path}
Introduced in
ONTAP 9.7
Usage notes
Updates the SnapLock retention time of a file or extends the retention time of a WORM file. Input parameters "expiry_time" or "retention_period" can be used to set or extend the retention time of file. Both "expiry_time" and "retention_period" parameters expect the date in ISO 8601 format. Additionally, the "expiry_time" parameter can also be set to "infinite" or "unspecified" and the "retention_period" parameter can also be set to "infinite". The input parameters are mutually exclusive.
  • volume file retention set
volume.uuid
string
path
True
Volume UUID
path
string
path
True
Path of the file in the form "/<dirpath>/<filename>"
Request Body
Name Type Description
expiry_time
string
Expiry time of the file in date-time format, "infinite", "indefinite", or "unspecified". An "infinite" retention time indicates that the file will be retained forever. An "unspecified" retention time indicates that the file will be retained forever; however, the retention time of the file can be changed to an absolute value. An "indefinite" retention time indicates that the file is under Legal-Hold.
is_expired
boolean
This indicates if the file is under active retention or if the file is past its expiry time.
retention_period
string
Duration of retention time file to be locked with, An "infinite" retention period indicates that the file will be retained forever.
seconds_until_expiry
integer
Specifies the number of seconds until the expiration time of the file.
Example request
  "expiry_time": "2058-06-04 15:00:00 -0400",
  "is_expired": 1,
  "retention_period": "P2M",
  "seconds_until_expiry": 168
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code
262179
Unexpected argument "" //end row //start row
262186 //end row //start row
Field "expiry_time" cannot be used with field "retention_period" //end row //start row
6691623 //end row //start row
User is not authorized //end row //start row
13763279 //end row //start row
The resulting expiry time due to the specified retention period is earlier than the current expiry time //end row //start row
14090348 //end row //start row
Invalid Expiry time //end row //start row
14090347 //end row //start row
File path must be in the format "/
/" //end row //start row
917804 //end row //start row
Path should be given in the format "/vol//". //end row
|Name |Type |Description
|href |string a|
[#_links] [.api-collapsible-fifth-title] _links [#svm] [.api-collapsible-fifth-title] svm
[cols=3*,options=header]
|name |string a|The name of the SVM. This field cannot be specified in a PATCH method.
|uuid |string a|The unique identifier of the SVM. This field cannot be specified in a PATCH method.
[#volume] [.api-collapsible-fifth-title] volume
|name |string a|The name of the volume. This field cannot be specified in a POST or PATCH method.
|uuid |string a|Unique identifier for the volume. This corresponds to the instance-uuid that is exposed in the CLI and ONTAPI. It does not change due to a volume move.
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
[#snaplock_file_retention] [.api-collapsible-fifth-title] snaplock_file_retention
|expiry_time |string a|Expiry time of the file in date-time format, "infinite", "indefinite", or "unspecified". An "infinite" retention time indicates that the file will be retained forever. An "unspecified" retention time indicates that the file will be retained forever; however, the retention time of the file can be changed to an absolute value. An "indefinite" retention time indicates that the file is under Legal-Hold.
|is_expired |boolean a|This indicates if the file is under active retention or if the file is past its expiry time.
|retention_period |string a|Duration of retention time file to be locked with, An "infinite" retention period indicates that the file will be retained forever.
|seconds_until_expiry |integer a|Specifies the number of seconds until the expiration time of the file.
[#error_arguments] [.api-collapsible-fifth-title] error_arguments
|code |string a|Argument code
|message |string a|Message argument
[#returned_error] [.api-collapsible-fifth-title] returned_error
|arguments |array[error_arguments] a|Message arguments
|code |string a|Error code
|message |string a|Error message
|target |string a|The target parameter that caused the error.
