REST API reference
Update the SnapLock retention time of a file
Updates the SnapLock retention time of a file, which allows you to manage file retention periods effectively. Use this endpoint when you need to adjust or extend the retention time of a Write Once, Read Many (WORM) file.
HTTP method and endpoint
PATCH /storage/snaplock/file/{volume.uuid}/{path}
Introduced in
ONTAP 9.7
Usage notes
Updates the SnapLock retention time of a file or extends the retention time of a WORM file. Input parameter "expiry_time" expects the date in ISO 8601 format, "infinite", or "unspecified".
  • volume file retention set
volume.uuid
string
path
True
Volume UUID
path
string
path
True
Path of the file in the form "/<dirpath>/<filename>"
Request Body
Name Type Description
expiry_time
string
Expiry time of the file in date-time format, "infinite", "indefinite", or "unspecified". An "infinite" retention time indicates that the file will be retained forever. An "unspecified" retention time indicates that the file will be retained forever; however, the retention time of the file can be changed to an absolute value. An "indefinite" retention time indicates that the file is under Legal-Hold.
Example request
  "expiry_time": "2058-06-04T19:00:00Z"
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code Description
14090347
File path must be in the format "/
14090348
Invalid Expiry time
string
svm
name
string
The name of the SVM.
uuid
string
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
snaplock_file_retention
expiry_time
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
