Update the SnapLock retention time of a file
Updates or extends the SnapLock retention time of a file to maintain compliance with data retention policies. Specify the retention period using the "expiry_time" or "retention_period" parameter in ISO 8601 format, or set either value to "infinite" or "unspecified" as needed.
HTTP method and endpoint
PATCH /storage/snaplock/file/{volume.uuid}/{path}
Introduced in
ONTAP 9.7
Usage notes
Updates the SnapLock retention time of a file or extends the retention time of a WORM file. Input parameters "expiry_time" or "retention_period" can be used to set or extend the retention time of file. Both "expiry_time" and "retention_period" parameters expect the date in ISO 8601 format. Additionally, the "expiry_time" parameter can also be set to "infinite" or "unspecified" and the "retention_period" parameter can also be set to "infinite". The input parameters are mutually exclusive.
Related ONTAP commands
volume file retention set
volume.uuid |
string |
path |
True |
Volume UUID |
path |
string |
path |
True |
Path of the file in the form "/<dirpath>/<filename>" |
Request Body
| Name | Type | Description |
expiry_time |
string |
Expiry time of the file in date-time format, "infinite", "indefinite", or "unspecified". An "infinite" retention time indicates that the file will be retained forever. An "unspecified" retention time indicates that the file will be retained forever; however, the retention time of the file can be changed to an absolute value. An "indefinite" retention time indicates that the file is under Legal-Hold. |
is_expired |
boolean |
This indicates if the file is under active retention or if the file is past its expiry time. |
retention_period |
string |
Duration of retention time file to be locked with, An "infinite" retention period indicates that the file will be retained forever. |
seconds_until_expiry |
integer |
Specifies the number of seconds until the expiration time of the file. |
Example request
"expiry_time": "2058-06-04 19:00:00 +0000",
"is_expired": 1,
"retention_period": "P2M",
"seconds_until_expiry": 168
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error code | Description |
262179 |
Unexpected argument " |
262186 |
Field "expiry_time" cannot be used with field "retention_period" |
6691623 |
User is not authorized |
13763279 |
The resulting expiry time due to the specified retention period is earlier than the current expiry time |
14090348 |
Invalid Expiry time |
14090347 |
File path must be in the format "\/<dir>\/<file path>" |
917804 |
Path should be given in the format "\/\vol\/<volume name>\/<file path>". |
href |
string |
_links
svm
name |
string |
uuid |
string |
volume
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
snaplock_file_retention
expiry_time |
string |
is_expired |
boolean |
retention_period |
string |
integer |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
