Download a software or firmware package
Downloads a software or firmware package from the server to access and install necessary updates or components for your system.
HTTP method and endpoint
POST /cluster/software/download
Introduced in
ONTAP 9.6
Required properties
url- URL location of the software package
Recommended optional parameters
username- Username of HTTPS/FTP server -
password- Password of HTTPS/FTP server
Related ONTAP commands
cluster image package get
Learn more
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
password |
string |
Password for download |
url |
string |
HTTP or FTP URL of the package through a server |
username |
string |
Username for download |
Example request
"password": "admin_password",
"url": "http://server/package",
"username": "admin"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default, Error
software_package_download
password |
string |
url |
string |
username |
string |
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
