REST API reference
Download a software or firmware package
Downloads a software or firmware package from the server to update or install new features on your system. Use this endpoint when you need to retrieve the latest software versions or firmware updates directly from the server.
HTTP method and endpoint
POST /cluster/software/download
Introduced in
ONTAP 9.6
Required properties
  • url - URL location of the software package
  • username - Username of HTTPS/FTP server
  • password - Password of HTTPS/FTP server
  • cluster image package get
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
password
string
Password for download
url
string
HTTP or FTP URL of the package through a server
username
string
Username for download
Example request
  "password": "admin_password",
  "url": "http://server/package",
  "username": "admin"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default, Error
software_package_download
password
string
url
string
username
string
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
