REST API reference
Download a software or firmware package
Downloads a software or firmware package from the server to update or install necessary components on your system. This is typically used to ensure your system is running the latest versions, enhancing performance and security.
HTTP method and endpoint
POST /cluster/software/download
Introduced in
ONTAP 9.6
Required properties
  • url - URL location of the software package
  • username - Username of HTTPS/FTP server
  • password - Password of HTTPS/FTP server
  • cluster image package get
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
password
string
Password for download
url
string
HTTP or FTP URL of the package through a server
username
string
Username for download
Example request
  "password": "admin_password",
  "url": "http://server/package",
  "username": "admin"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default, Error
software_package_download
password
string
url
string
username
string
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
