Download a software or firmware package
Downloads a software or firmware package from the server to acquire the necessary updates for your system. This operation is typically used when you need to update or install software components on your ONTAP systems.
HTTP method and endpoint
POST /cluster/software/download
Introduced in
ONTAP 9.6
Required properties
url- URL location of the software package
Recommended optional parameters
username- Username of HTTPS/FTP server -
password- Password of HTTPS/FTP server
Related ONTAP commands
cluster image package get
Learn more
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
code |
integer |
Code returned corresponds to a download message. |
message |
string |
Download progress details. |
password |
string |
Password for download |
state |
string |
Download status of the package. |
url |
string |
HTTP or FTP URL of the package through a server |
username |
string |
Username for download |
Example request
"code": 10551382,
"message": "Package download in progress",
"password": "admin_password",
"state": "success",
"url": "http://server/package",
"username": "admin"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10551327 |
Package image with the same name already exists. |
10551357 |
Cannot perform an update when a previous update is still in progress. |
10551359 |
Internal error. Failed to process the package after download completed. Try uploading the file again or contact technical support for assistance. |
10551381 |
Package download failed. |
10551382 |
Package download is still running. |
10551384 |
Package download has not started. |
10551391 |
Internal error. Contact technical support for assistance. |
10551392 |
10551496 |
Firmware file already exists. |
10551797 |
Internal error. Failed to check if file upload is enabled. Contact technical support for assistance. |
10551859 |
Failed to set primary and secondary nodes to store new image. |
10551885 |
Package download failed due to invalid url. |
10551892 |
Package download failed due to an unhealthy node. Restore the node to a healthy state, then retry the operation. |
39387137 |
Invalid URL syntax was provided. Retry with a valid URL. |
39387138 |
Unsupported URL scheme provided. Retry with one of FILE://, FTP://, or HTTPS://. |
software_package_download
code |
integer |
message |
string |
password |
string |
state |
string |
url |
string |
username |
string |
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
