Download a software or firmware package
Downloads a software or firmware package from the server. Use this operation to retrieve essential files for updates or system maintenance.
HTTP method and endpoint
POST /cluster/software/download
Introduced in
ONTAP 9.6
Required properties
url- URL location of the software package
Recommended optional parameters
username- Username of HTTPS/FTP server -
password- Password of HTTPS/FTP server
Related ONTAP commands
cluster image package get
Learn more
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
password |
string |
Password for download |
url |
string |
HTTP or FTP URL of the package through a server |
username |
string |
Username for download |
Example request
"password": "admin_password",
"url": "http://server/package",
"username": "admin"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10551327 |
Package image with the same name already exists. |
10551357 |
Cannot perform an update when a previous update is still in progress. |
10551359 |
Internal error. Failed to process the package after download completed. Try uploading the file again or contact technical support for assistance. |
10551381 |
Package download failed. |
10551382 |
Package download is still running. |
10551384 |
Package download has not started. |
10551391 |
Internal error. Contact technical support for assistance. |
10551392 |
10551496 |
Firmware file already exists. |
10551797 |
Internal error. Failed to check if file upload is enabled. Contact technical support for assistance. |
10551859 |
Failed to set primary and secondary nodes to store new image. |
39387137 |
Invalid URL syntax was provided. Retry with a valid URL. |
39387138 |
Unsupported URL scheme provided. Retry with one of FILE://, FTP://, or HTTPS://. |
software_package_download
password |
string |
url |
string |
username |
string |
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
