REST API reference
Download a software or firmware package
Downloads a software or firmware package from the server to acquire the necessary updates for your system. This operation is typically used when you need to update or install software components on your ONTAP systems.
HTTP method and endpoint
POST /cluster/software/download
Introduced in
ONTAP 9.6
Required properties
  • url - URL location of the software package
  • username - Username of HTTPS/FTP server
  • password - Password of HTTPS/FTP server
  • cluster image package get
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
code
integer
Code returned corresponds to a download message.
message
string
Download progress details.
password
string
Password for download
state
string
Download status of the package.
url
string
HTTP or FTP URL of the package through a server
username
string
Username for download
Example request
  "code": 10551382,
  "message": "Package download in progress",
  "password": "admin_password",
  "state": "success",
  "url": "http://server/package",
  "username": "admin"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
10551327
Package image with the same name already exists.
10551357
Cannot perform an update when a previous update is still in progress.
10551359
Internal error. Failed to process the package after download completed. Try uploading the file again or contact technical support for assistance.
10551381
Package download failed.
10551382
Package download is still running.
10551384
Package download has not started.
10551391
Internal error. Contact technical support for assistance.
10551392
10551496
Firmware file already exists.
10551797
Internal error. Failed to check if file upload is enabled. Contact technical support for assistance.
10551859
Failed to set primary and secondary nodes to store new image.
10551885
Package download failed due to invalid url.
10551892
Package download failed due to an unhealthy node. Restore the node to a healthy state, then retry the operation.
39387137
Invalid URL syntax was provided. Retry with a valid URL.
39387138
Unsupported URL scheme provided. Retry with one of FILE://, FTP://, or HTTPS://.
software_package_download
code
integer
message
string
password
string
state
string
url
string
username
string
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
