View and update IPsec configuration
Access and modify IPsec configuration to manage secure communication within your network environment. Use these endpoints to retrieve current status and apply updates as needed.
Overview
The following operations are supported:
GET to retrieve the IPsec status: GET security/ipsec
Patch to update IPsec status: PATCH security/ipsec
