View and update IPsec configuration
Retrieve and modify IPsec configurations to manage secure communication settings within your network. Use these endpoints to check and update the IPsec status as needed for maintaining security standards.
Overview
The following operations are supported:
GET to retrieve the IPsec status: GET security/ipsec
Patch to update IPsec status: PATCH security/ipsec
