View and update IPsec configuration
Access and modify IPsec configuration settings to secure data transmitted across your network. Use these endpoints to retrieve the current IPsec status or update it as necessary.
Overview
The following operations are supported:
GET to retrieve the IPsec status: GET security/ipsec
Patch to update IPsec status: PATCH security/ipsec
