REST API reference
View and update IPsec configuration
Access and modify IPsec configuration settings to manage secure communications within your network. Use these endpoints to check the current IPsec status or update configurations as needed.
Overview
The following operations are supported:
  • GET to retrieve the IPsec status: GET security/ipsec
  • Patch to update IPsec status: PATCH security/ipsec
