View and update IPsec configuration
Access and modify IPsec configuration settings to ensure secure data transmission within your network. Use these endpoints to retrieve current IPsec status or apply updates as needed.
Overview
The following operations are supported:
GET to retrieve the IPsec status: GET security/ipsec
Patch to update IPsec status: PATCH security/ipsec
