View and update IPsec configuration
Retrieve and update the IPsec configuration to manage secure communication settings for your network connections. Use these endpoints to check current IPsec status or modify the configuration as required.
Overview
The following operations are supported:
GET to retrieve the IPsec status: GET security/ipsec
Patch to update IPsec status: PATCH security/ipsec
