Create an S3 user configuration
Creates an S3 user configuration to manage user access within an SVM. Use this endpoint to generate an access key and secret key for the new user.
HTTP method and endpoint
POST /protocols/s3/services/{svm.uuid}/users
Introduced in
ONTAP 9.7
Important notes
Each SVM can have one or more user configurations.
If user creation is successful, a user access_key and secret_key is returned as part of the response.
Required properties
svm.uuid- Existing SVM in which to create the user configuration. -
name- User name that is to be created.
Default property values
comment- ""
Related ONTAP commands
vserver object-store-server user create
Learn more
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
access_key |
string |
Specifies the access key for the user. |
comment |
string |
Can contain any additional information about the user being created or modified. |
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
svm |
Example request
"access_key": "Pz3SB54G2B_6dsXQPrA5HrTPcf478qoAW6_Xx6qyqZ948AgZ_7YfCf_9nO87YoZmskxx3cq41U2JAH2M3_fs321B4rkzS3a_oC5_8u7D8j_45N8OsBCBPWGD_1d_ccfq",
"comment": "S3 user",
"name": "user-1",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
"num_records": 1,
"records": [
"name": "user-1",
"secret_key": "A20_tDhC_cux2C2BmtL45bXB_a_Q65c_96FsAcOdo14Az8V31jBKDTc0uCL62Bh559gPB8s9rrn0868QrF38_1dsV2u1_9H2tSf3qQ5xp9NT259C6z_GiZQ883Qn63X1"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405773 |
Object store server is not present for specified SVM. Create a object store server and retry the operation. |
92405787 |
The specified user name contains invalid characters. Valid characters for a user name are 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-". |
92405788 |
User names must have between 1 and 64 characters. |
92405791 |
Failed to create access-key and secret-key. |
92405817 |
S3 users can be created only on data SVM. |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
s3_user
This is a container of S3 users.
access_key |
string |
comment |
string |
name |
string |
svm |
collection_links
s3_service_user_post_response
access_key |
string |
name |
string |
The name of the user. |
secret_key |
string |
Specifies the secret key for the user. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
