REST API reference
Create an S3 user configuration
Creates an S3 user configuration to define access for S3 services within a specific SVM. This operation is useful for managing user credentials and permissions for S3 interactions.
HTTP method and endpoint
POST /protocols/s3/services/{svm.uuid}/users
Introduced in
ONTAP 9.7
Important notes
  • Each SVM can have one or more user configurations.
  • If user creation is successful, a user access_key and secret_key is returned as part of the response.
Required properties
  • svm.uuid - Existing SVM in which to create the user configuration.
  • name - User name that is to be created.
Default property values
  • comment - ""
  • vserver object-store-server user create
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
access_key
string
Specifies the access key for the user.
comment
string
Can contain any additional information about the user being created or modified.
name
string
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
svm
svm
Example request
  "access_key": "Pz3SB54G2B_6dsXQPrA5HrTPcf478qoAW6_Xx6qyqZ948AgZ_7YfCf_9nO87YoZmskxx3cq41U2JAH2M3_fs321B4rkzS3a_oC5_8u7D8j_45N8OsBCBPWGD_1d_ccfq",
  "comment": "S3 user",
  "name": "user-1",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records
records
array[s3_service_user_post_response]
  "records": [
      "name": "user-1",
      "secret_key": "A20_tDhC_cux2C2BmtL45bXB_a_Q65c_96FsAcOdo14Az8V31jBKDTc0uCL62Bh559gPB8s9rrn0868QrF38_1dsV2u1_9H2tSf3qQ5xp9NT259C6z_GiZQ883Qn63X1"
Status: Default
ONTAP Error Response Codes
Error Code Description
92405773
Object store server is not present for specified SVM. Create a object store server and retry the operation.
92405787
The specified user name contains invalid characters. Valid characters for a user name are 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-".
92405788
User names must have between 1 and 64 characters.
92405791
Failed to create access-key and secret-key.
92405817
S3 users can be created only on data SVM.
string
svm
name
string
The name of the SVM.
uuid
string
s3_user
This is a container of S3 users.
access_key
string
comment
string
name
string
svm
svm
access_key
string
name
string
The name of the user.
secret_key
string
Specifies the secret key for the user.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
