Create an S3 user configuration
Creates an S3 user configuration to manage user access to S3 services within an ONTAP cluster.
HTTP method and endpoint
POST /protocols/s3/services/{svm.uuid}/users
Introduced in
ONTAP 9.7
Important notes
Each SVM can have one or more user configurations.
If the user is a member of Active directory, the user name takes the format "user@FQDN". For example, "user1@domain1.com".
If user creation is successful, a user access_key and secret_key is returned as part of the response.
If user keys have expiry configuration, then "key_expiry_time" is also returned as part of the response.
User access and secret keys can be specified in the input. If not specified, keys are generated automatically.
Required properties
svm.uuid- Existing SVM in which to create the user configuration. -
name- User name that is to be created.
Default property values
comment- ""
Related ONTAP commands
vserver object-store-server user create
Learn more
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
access_key |
string |
Specifies the access key for the user. |
comment |
string |
Can contain any additional information about the user being created or modified. |
key_expiry_time |
string |
Specifies the date and time after which keys expire and are no longer valid. |
key_time_to_live |
string |
Indicates the time period from when this parameter is specified:
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
secret_key |
string |
Specifies the secret key for the user. |
svm |
Example request
"access_key": "<AWS-ACCESS-KEY-ID>",
"comment": "S3 user",
"key_expiry_time": "2023-12-31 19:00:00 -0500",
"key_time_to_live": "PT6H3M",
"name": "user-1",
"secret_key": "<AWS-SECRET-ACCESS-KEY>",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
"num_records": 1,
"records": [
"name": "user-1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405787 |
User name "User#1" contains invalid characters. Valid characters for a user name are 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-". |
92405788 |
User name "User0123456789012345678901234567890123456789012345678901234567890123456789012345" is not valid. User names must have between 1 and 64 characters. |
92405791 |
Failed to create access-key and secret-key. |
92405817 |
SVM " |
92406083 |
The maximum supported value for user key expiry configuration is "1095" days. |
92406096 |
The user does not have permission to access the requested resource \"{0}\". |
92406097 |
Internal error. The operation configuration is not correct. |
92406196 |
The specified value for the "key_time_to_live" field cannot be greater than the maximum limit specified for the "max_key_time_to_live" field in the object store server. |
| 92406197 | Object store user "user-2" must have a non-zero value for the "key_time_to_live" field because the maximum limit specified for the "max_key_time_to_live" field in the object store server is not zero. | 92406200 | An object store user with the same access-key already exists. | | 92406201 | Missing access-key or secret-key. Either provide both of the keys or none. If not provided, keys are generated automatically. | | 92406205 | The object store user access key contains invalid characters. Valid characters are 0-9 and A-Z. |
href |
string |
_links
svm
name |
string |
uuid |
string |
s3_user
This is a container of S3 users.
access_key |
string |
comment |
string |
key_expiry_time |
string |
key_time_to_live |
string |
name |
string |
secret_key |
string |
svm |
collection_links
s3_service_user_post_response
access_key |
string |
key_expiry_time |
string |
Specifies the date and time after which the keys expire and are no longer valid. |
name |
string |
The name of the user. |
secret_key |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
