Create an S3 user configuration
Creates an S3 user configuration to manage access credentials for S3 operations within an SVM. This is useful when setting up and managing user-specific access to object storage resources.
HTTP method and endpoint
POST /protocols/s3/services/{svm.uuid}/users
Introduced in
ONTAP 9.7
Important notes
Each SVM can have one or more user configurations.
If the user is a member of Active directory, the user name takes the format "user@FQDN". For example, "user1@domain1.com".
If user creation is successful, a user access_key and secret_key is returned as part of the response.
If user keys have expiry configuration, then "key_expiry_time" is also returned as part of the response.
Required properties
svm.uuid- Existing SVM in which to create the user configuration. -
name- User name that is to be created.
Default property values
comment- ""
Related ONTAP commands
vserver object-store-server user create
Learn more
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
access_key |
string |
Specifies the access key for the user. |
comment |
string |
Can contain any additional information about the user being created or modified. |
key_expiry_time |
string |
Specifies the date and time after which keys expire and are no longer valid. |
key_time_to_live |
string |
Indicates the time period from when this parameter is specified:
name |
string |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-". |
svm |
Example request
"access_key": "<AWS-ACCESS-KEY-ID>",
"comment": "S3 user",
"key_expiry_time": "2023-12-31 19:00:00 -0500",
"key_time_to_live": "PT6H3M",
"name": "user-1",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
"num_records": 1,
"records": [
"name": "user-1",
"secret_key": "<AWS-SECRET-ACCESS-KEY>"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405787 |
User name "User#1" contains invalid characters. Valid characters for a user name are 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-". |
92405788 |
User name "User0123456789012345678901234567890123456789012345678901234567890123456789012345" is not valid. User names must have between 1 and 64 characters. |
92405791 |
Failed to create access-key and secret-key. |
92405817 |
SVM " |
//end row //start row |
92406083 //end row //start row |
The maximum supported value for user key expiry configuration is "1095" days. //end row //start row |
92406096 //end row //start row |
The user does not have permission to access the requested resource "{0}". //end row //start row |
92406097 //end row //start row |
Internal error. The operation configuration is not correct. //end row //start row |
92406196 //end row //start row |
The specified value for the "key_time_to_live" field cannot be greater than the maximum limit specified for the "max_key_time_to_live" field in the object store server. //end row //start row |
92406197 //end row //start row |
Object store user "user-2" must have a non-zero value for the "key_time_to_live" field because the maximum limit specified for the "max_key_time_to_live" field in the object store server is not zero. //end row |
|Name |Type |Description
|href |string a|
[#_links] [.api-collapsible-fifth-title] _links [#svm] [.api-collapsible-fifth-title] svm SVM, applies only to SVM-scoped objects. [cols=3*,options=header] |
|name |string a|The name of the SVM. This field cannot be specified in a PATCH method.
|uuid |string a|The unique identifier of the SVM. This field cannot be specified in a PATCH method.
[#s3_user] [.api-collapsible-fifth-title] s3_user This is a container of S3 users. [cols=3*,options=header] |
|access_key |string a|Specifies the access key for the user.
|comment |string a|Can contain any additional information about the user being created or modified.
|key_expiry_time |string a|Specifies the date and time after which keys expire and are no longer valid.
|key_time_to_live |string a|Indicates the time period from when this parameter is specified:
when creating or modifying a user or
when the user keys were last regenerated, after which the user keys expire and are no longer valid.
Valid format is: 'PnDTnHnMnS\|PnW'. For example, P2DT6H3M10S specifies a time period of 2 days, 6 hours, 3 minutes, and 10 seconds.
If the value specified is '0' seconds, then the keys won't expire.
|name |string a|Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
|svm |svm a|SVM, applies only to SVM-scoped objects.
[#collection_links] [.api-collapsible-fifth-title] collection_links [#s3_service_user_post_response] [.api-collapsible-fifth-title] s3_service_user_post_response [cols=3*,options=header] |
|key_expiry_time |string a|Specifies the date and time after which the keys expire and are no longer valid.
|name |string a|The name of the user.
|secret_key |string a|Specifies the secret key for the user.
[#error_arguments] [.api-collapsible-fifth-title] error_arguments [cols=3*,options=header] |
|code |string a|Argument code
|message |string a|Message argument
[#returned_error] [.api-collapsible-fifth-title] returned_error [cols=3*,options=header] |
|arguments |array[error_arguments] a|Message arguments
|code |string a|Error code
|message |string a|Error message
|target |string a|The target parameter that caused the error.
