REST API reference
Create an S3 user configuration
POST /protocols/s3/services/{svm.uuid}/users
Introduced In: 9.7
Creates the S3 user configuration.
Important notes
  • Each SVM can have one or more user configurations.
  • If the user is a member of Active directory, the user name takes the format "user@FQDN". For example, "user1@domain1.com".
  • If user creation is successful, a user access_key and secret_key is returned as part of the response.
  • If user keys have expiry configuration, then "key_expiry_time" is also returned as part of the response.
  • User access and secret keys can be specified in the input. If not specified, keys are generated automatically.
Required properties
  • svm.uuid - Existing SVM in which to create the user configuration.
  • name - User name that is to be created.
Default property values
  • comment - ""
  • vserver object-store-server user create
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
access_key
string
Specifies the access key for the user.
comment
string
Can contain any additional information about the user being created or modified.
key_expiry_time
string
Specifies the date and time after which keys expire and are no longer valid.
key_time_to_live
string
Indicates the time period from when this parameter is specified:
  • when creating or modifying a user or
  • when the user keys were last regenerated, after which the user keys expire and are no longer valid.
  • Valid format is: 'PnDTnHnMnS|PnW'. For example, P2DT6H3M10S specifies a time period of 2 days, 6 hours, 3 minutes, and 10 seconds.
  • If the value specified is '0' seconds, then the keys won't expire.
name
string
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
secret_key
string
Specifies the secret key for the user.
svm
svm
Example request
  "access_key": "<AWS-ACCESS-KEY-ID>",
  "comment": "S3 user",
  "key_expiry_time": "2024-01-01 00:00:00 +0000",
  "key_time_to_live": "PT6H3M",
  "name": "user-1",
  "secret_key": "<AWS-SECRET-ACCESS-KEY>",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records
records
array[s3_service_user_post_response]
  "num_records": 1,
  "records": [
      "name": "user-1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
92405787
User name "User#1" contains invalid characters. Valid characters for a user name are 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-".
92405788
User name "User0123456789012345678901234567890123456789012345678901234567890123456789012345" is not valid. User names must have between 1 and 64 characters.
92405791
Failed to create access-key and secret-key.
92405817
SVM "{non-data SVM name}" is not a data SVM. Specify a data SVM.
92406083
The maximum supported value for user key expiry configuration is "1095" days.
92406096
The user does not have permission to access the requested resource "{0}".
92406097
Internal error. The operation configuration is not correct.
92406196
The specified value for the "key_time_to_live" field cannot be greater than the maximum limit specified for the "max_key_time_to_live" field in the object store server.
92406197
Object store user "user-2" must have a non-zero value for the "key_time_to_live" field because the maximum limit specified for the "max_key_time_to_live" field in the object store server is not zero.
92406200
An object store user with the same access-key already exists.
92406201
Missing access-key or secret-key. Either provide both of the keys or none. If not provided, keys are generated automatically.
92406205
The object store user access key contains invalid characters. Valid characters are 0-9 and A-Z.
string
svm
name
string
uuid
string
s3_user
This is a container of S3 users.
access_key
string
comment
string
key_expiry_time
string
key_time_to_live
string
name
string
secret_key
string
svm
svm
access_key
string
key_expiry_time
string
Specifies the date and time after which the keys expire and are no longer valid.
name
string
The name of the user.
secret_key
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
