REST API reference
Create an S3 user configuration
Creates an S3 user configuration within an SVM. This configuration is useful for managing access to object storage resources in ONTAP.
HTTP method and endpoint
POST /protocols/s3/services/{svm.uuid}/users
Introduced in
ONTAP 9.7
Important notes
  • Each SVM can have one or more user configurations.
  • If the user is a member of Active directory, the user name takes the format "user@FQDN". For example, "user1@domain1.com".
  • If user creation is successful, a user access_key and secret_key is returned as part of the response.
  • If user keys have expiry configuration, then "key_expiry_time" is also returned as part of the response.
  • User access and secret keys can be specified in the input. If not specified, keys are generated automatically.
Required properties
  • svm.uuid - Existing SVM in which to create the user configuration.
  • name - User name that is to be created.
Default property values
  • comment - ""
  • vserver object-store-server user create
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
access_key
string
Specifies the access key for the user.
comment
string
Can contain any additional information about the user being created or modified.
key_expiry_time
string
Specifies the date and time after which keys expire and are no longer valid.
key_time_to_live
string
Indicates the time period from when this parameter is specified:
  • when creating or modifying a user or
  • when the user keys were last regenerated, after which the user keys expire and are no longer valid.
  • Valid format is: 'PnDTnHnMnS|PnW'. For example, P2DT6H3M10S specifies a time period of 2 days, 6 hours, 3 minutes, and 10 seconds.
  • If the value specified is '0' seconds, then the keys won't expire.
name
string
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".
secret_key
string
Specifies the secret key for the user.
svm
svm
Example request
  "access_key": "HJAKU28M3SXTE2UXUACV",
  "comment": "S3 user",
  "key_expiry_time": "2023-12-31 19:00:00 -0500",
  "key_time_to_live": "PT6H3M",
  "name": "user-1",
  "secret_key": "dummy_secret_key_1234_abcd_ldjf",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records
records
array[s3_service_user_post_response]
  "num_records": 1,
  "records": [
      "name": "user-1",
      "secret_key": "BcA_HX6If458llhnx3n1TCO3mg4roCXG0ddYf_cJ"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
92405787
User name "User#1" contains invalid characters. Valid characters for a user name are 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-".
92405788
User name "User0123456789012345678901234567890123456789012345678901234567890123456789012345" is not valid. User names must have between 1 and 64 characters.
92405791
Failed to create access-key and secret-key.
92405817
SVM "<non-data SVM name>" is not a data SVM. Specify a data SVM.
92406083
The maximum supported value for user key expiry configuration is "1095" days.
92406096
The user does not have permission to access the requested resource "{0}".
92406097
Internal error. The operation configuration is not correct.
92406196
The specified value for the "key_time_to_live" field cannot be greater than the maximum limit specified for the "max_key_time_to_live" field in the object store server.
92406197
Object store user "user-2" must have a non-zero value for the "key_time_to_live" field because the maximum limit specified for the "max_key_time_to_live" field in the object store server is not zero.
92406200
An object store user with the same access-key already exists.
92406201
Missing access-key or secret-key. Either provide both of the keys or none. If not provided, keys are generated automatically.
92406205
The object store user access key contains invalid characters. Valid characters are 0-9 and A-Z.
string
svm
name
string
uuid
string
s3_user
This is a container of S3 users.
access_key
string
comment
string
key_expiry_time
string
key_time_to_live
string
name
string
secret_key
string
svm
svm
access_key
string
key_expiry_time
string
Specifies the date and time after which the keys expire and are no longer valid.
name
string
The name of the user.
secret_key
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
