Create an S3 user configuration
POST /protocols/s3/services/{svm.uuid}/users
Creates the S3 user configuration.
Important notes
Each SVM can have one or more user configurations.
If user creation is successful, a user access_key and secret_key is returned as part of the response.
Required properties
svm.uuid- Existing SVM in which to create the user configuration. -
name- User name that is to be created.
Default property values
comment- ""
Related ONTAP commands
vserver object-store-server user create
Learn more
return_records  |
boolean  |
query  |
False  |
The default is false. If set to true, the records are returned.  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
Request Body
| Name | Type | Description |
access_key  |
string  |
Specifies the access key for the user.  |
comment  |
string  |
Can contain any additional information about the user being created or modified.  |
name  |
string  |
Specifies the name of the user. A user name length can range from 1 to 64 characters and can only contain the following combination of characters 0-9, A-Z, a-z, "_", "+", "=", ",", ".","@", and "-".  |
svm  |
Example request
  "access_key": "Pz3SB54G2B_6dsXQPrA5HrTPcf478qoAW6_Xx6qyqZ948AgZ_7YfCf_9nO87YoZmskxx3cq41U2JAH2M3_fs321B4rkzS3a_oC5_8u7D8j_45N8OsBCBPWGD_1d_ccfq",
  "comment": "S3 user",
  "name": "user-1",
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
Status: 201, Created
num_records  |
integer  |
Number of records  |
records  |
  "records": [
        "next": {
      "name": "user-1",
      "secret_key": "A20_tDhC_cux2C2BmtL45bXB_a_Q65c_96FsAcOdo14Az8V31jBKDTc0uCL62Bh559gPB8s9rrn0868QrF38_1dsV2u1_9H2tSf3qQ5xp9NT259C6z_GiZQ883Qn63X1"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405773  |
Object store server is not present for specified SVM. Create a object store server and retry the operation.  |
92405787  |
The specified user name contains invalid characters. Valid characters for a user name are 0-9, A-Z, a-z, "_", "+", "=", ",", ".", "@", and "-".  |
92405788  |
User names must have between 1 and 64 characters.  |
92405791  |
Failed to create access-key and secret-key.  |
92405817  |
S3 users can be created only on data SVM.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
s3_user
This is a container of S3 users.
access_key  |
string  |
comment  |
string  |
name  |
string  |
svm  |
collection_links
next  |
self  |
s3_service_user_post_response
_links  |
access_key  |
string  |
name  |
string  |
The name of the user.  |
secret_key  |
string  |
Specifies the secret key for the user.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
