REST API reference
Add a privilege tuple (of rest uri and its access level) to an existing role
  • name - name of the role to be updated
  • path - rest uri path (example: "/api/storage/volumes")
  • access - desired access level for the rest uri path (one of "all", "readonly" or "none") # optional parameters none # related ontap commands
  • security login rest-role create # learn more
  • [doc /security/roles/{owneruuid}/{name}/privileges](#docs-security-security_roles_{owneruuid}_{name}_privileges)
  • [doc /security/roles](#docs-security-security_roles)
POST /security/roles/{owner.uuid}/{name}/privileges
Add a privilege tuple (of REST URI and its access level) to an existing role.
Required parameters
  • owner.uuid - UUID of the SVM that houses this role.
  • name - Name of the role to be updated.
  • path - REST URI path (example: "/api/storage/volumes").
  • access - Desired access level for the REST URI path (one of "all", "readonly" or "none").
Optional parameters
none
owner.uuid
string
path
True
Owner UUID of the role.
name
string
path
True
Role name
Request Body
Name Type Description
_links
_links
access
string
Access level for the REST endpoint.
path
string
REST URI/endpoint
Example request
      "href": "/api/resourcelink"
  "access": "readonly",
  "path": "/api/storage/volumes"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
13434891
UUID LookUp failed for Vserver roles.
13434890
Vserver-Id failed for Vserver roles.
13434892
Roles is a required field.
13434893
SVM does not exist.
5636173
This feature requires an effective cluster version of 9.6 or later.
5636129
Role with given name has not been defined.
5636169
Invalid character in URI.
5636170
URI does not exist.
5636175
Vserver admin cannot have access to given API.
5636144
Invalid value specified for the access level.
5636143
A Vserver admin cannot use the API with this access level.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
role_privilege
A tuple containing the REST endpoint and the access level assigned to that endpoint.
_links
_links
access
string
path
string
REST URI/endpoint
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
