REST API reference
Migrate SVM keys between security key managers
POST /security/key-managers/{source.uuid}/migrate
Introduced In: 9.7
Migrates the keys belonging to an SVM between the cluster's key manager and the SVM's key manager. This operation can run for several minutes.
Required properties
  • source.uuid - UUID of the source key manager.
  • uuid - UUID of the destination key manager.
  • security key-manager migrate
source.uuid
string
path
True
Migration source key manager UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
uuid
string
Key manager UUID
Example request
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default, Error
string
info
Migration destination key manager UUID
uuid
string
Key manager UUID
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
