NetApp Technical Reports
ONTAP storage efficiency technical reports
Contributors netapp-chrisgeb netapp-dbagwell netapp-aherbin
ONTAP provides a comprehensive portfolio of storage efficiency capabilities. Inline data compression, deduplication, and compaction work together to reduce your storage costs and maximize the data you can store. Plus, you can multiply your savings with space-efficient NetApp Snapshot copies, thin provisioning, replication, and cloning technologies.
Note
Procedural documentation for deduplication can be found at deduplication documentation
Procedural documentation for compression can be found at compression documentation
Procedural documentation for temperature sensitive storage efficiency can be found at temperature sensitive storage efficiency documentation
Procedural documentation for compaction can be found at compaction documentation
