Setup and administration
Log in to NetApp Workload Factory
Contributors netapp-rlithman netapp-bcammett netapp-tonacki
After you sign up to NetApp Workload Factory, you can log in at any time from the web-based console to start managing your workloads and FSx for ONTAP file systems.
About this task
You can log in to the Workload Factory web-based console using one of the following options:
  • Your existing NetApp Support Site (NSS) credentials
  • A NetApp cloud login using your email address and a password
Steps
  1. Open a web browser and go to the Workload Factory console.
  2. On the Log in page, enter the email address that's associated with your login.
  3. Depending on the authentication method associated with your login, you'll be prompted to enter your credentials:
    • NetApp cloud credentials: Enter your password
    • Federated user: Enter your federated identity credentials
    • NetApp Support Site account: Enter your NetApp Support Site credentials
  4. Select Log in.
    If you have successfully logged in in the past, you'll see the Workload Factory home page and you'll be using the default account.
    If this is the first time that you've logged in, you'll be directed to the Account page.
    • If you are a member of a single account, select Continue.
    • If you are a member of multiple accounts, select the account and select Continue.
Result
You're now logged in and can start using Workload Factory to manage FSx for ONTAP file systems and your workloads.
