Setup and administration
Remove credentials from NetApp Workload Factory
Contributors netapp-tonacki netapp-rlithman netapp-bcammett netapp-sineadd
If you no longer need a set of credentials, you can delete them from Workload Factory. You can only delete credentials that aren't associated with an FSx for ONTAP file system.
Steps
  1. Log in using one of the console experiences.
  2. From the menu, select Administration and then Credentials.
  3. On the Credentials page, do the following:
    • In the Workload Factory console, select the action menu for a set of credentials and then select Remove. Select Remove to confirm.
    • In the NetApp Console, select the action menu for a set of credentials and then select Delete. Select Delete to confirm.
