Restore cloud-native Oracle databases to original location
In the event of data loss, you can restore the data files, control files, or both to original location and then recover the database.
If the Oracle 21c database is in STARTED state, the restore operation fails. You should run the following command to restore the database successfully.
cp -f <ORACLE_HOME>/jdbc/lib/ojdbc8.jar /opt/NetApp/snapcenter/spl/plugins/sco/lib/ojdbc8-8.jar
Click corresponding to the database that you want to restore and click Restore.
Select the restore point to which the database should be restored and click Restore to original location.
In the Restore Scope section, perform the following actions:
If you… Do this… Want to restore only the data files
Select All Data Files.
Want to restore only the control files
Select Control Files
Want to restore both data files and control files
Select All Data Files and Control Files.
You can also select Force in-place restore checkbox.
In Amazon FSx for NetApp ONTAP or Cloud Volumes ONTAP SAN layout, if SnapCenter Plug-in for Oracle finds any foreign files other than Oracle data files on the ASM diskgroup, connect and copy restore method is performed. The foreign files could be one or more of the following types:
Parameter
Password
archive log
online log
ASM parameter file.
The Force in-place restore option overrides the foreign files of type parameter, password, and archive log. You should use the latest backup when Force in-place restore option is selected.
In the Recovery Scope section, perform the following actions:
If you… Do this… Want to recover to the last transaction
Select All Logs.
Want to recover to a specific System Change Number (SCN)
Select Until SCN and specify the SCN.
Want to recover to a specific date and time
Select Date and Time.
Do not want to recover
Select No recovery.
For the selected recovery scope, in the Archive Log Files Locations field you can optionally specify the location that contains the archive logs required for recovery.
Select the check box if you want to open the database in READ-WRITE mode after recovery.
Click Next and review the details.
Click Restore.
