BlueXP backup and recovery
All cloud providers
  • Amazon Web Services
  • Google Cloud
  • Microsoft Azure
  • All cloud providers
Restore Microsoft SQL Server database
Contributors netapp-soumikd
You can restore Microsoft SQL Server database to the same host. You should first get list of databases and then restore the database.
View the list of databases
You can run this API to view the list of databases.
'GET snapcenter.cloudmanager.cloud.netapp.com/api/mssql/databases'
If the API is executed successfully, response code 200 is displayed.
Example:
    "num_records": 3,
    "total_records": 3,
    "records": [
            "id": "348901e5-aeaa-419f-88b1-80240de3b1fe",
            "name": "DB4",
            "hostname": "scspa2722211001.rtp.openenglab.netapp.com",
            "size": 0.078125,
            "instance_id": "454c8413-5351-41fc-88bf-f20fb050ec87",
            "instance": "scspa2722211001\\NAMEDINSTANCE1",
            "db_status": "Normal",
            "db_access": "eUndefined",
            "db_type": "User",
            "recovery_mode": "Full"
            "id": "c79d33ab-7322-4ed6-92f5-51ad7a6944e0",
            "name": "DB5",
            "size": 0.078125,
            "db_type": "User",
            "id": "40d6f35a-f4fb-48bc-8e0a-0ac93ddf0888",
            "name": "model",
            "size": 0.015625,
            "db_type": "System",
        "next": {}
Restore and recover the MSSQL database
You can run this API to restore the MSSQL database.
'POST snapcenter.cloudmanager.cloud.netapp.com/api/mssql/databases/{id}/restore'
Where, id is MSSQL database ID obtained by running the view database API. For more information, refer to View the list of databases.
This API creates a job that can be tracked from the Job Monitor tab in the BlueXP UI.
Name Type Required
backup_id
string
True
overwrite_database
bool
True
retain_replication_settings
bool
False
recovery_mode
string
The 3 supported strings are Operational, NonOperational, and ReadOnly.
True
undo_file_directory
string
True
restore_type
string
True
If the API is executed successfully, response code 202 is displayed.
Example:
  "job": {
        "href": "/api/resourcelink"
    "uuid": "3fa85f64-5717-4562-b3fc-2c963f66afa6"
