Persistently enable the switches
PDF of this doc site
Upgrade by using ARL
- Use "system controller replace" commands to upgrade controller models in the same chassis
Creating your file...
Your file is ready
You must enable the switches in the fabric persistently.
Step
Persistently enable the switch:
For Brocade switches, use the
switchCfgPersistentenable
command.FC_switch_A_1:admin> switchCfgPersistentenable
For Cisco switches, use the
no suspend
command.vsan [vsna #]no suspend
