Migrate LIFs and data aggregates on node2 to node1
Contributors netapp-pcarriga
Before converting AFF A250 node2 to a drive shelf, you migrate the logical interfaces (LIFs) and data aggregates on node2 to node1.
Before you begin
Verify that you meet the following requirements:
  • The AFF A250 and AFF A400 controllers are running the same ONTAP release and patch version.
    Note
    • You must netboot and install the ONTAP version on each AFF A400 that is identical to the version running on the AFF A250.
    • Both the primary and backup boot image of each AFF A400 must have the same ONTAP version.
    • If the AFF A400 clusters were previously configured, you must clear any residual cluster configuration by performing a wipeconfig from the boot menu.
  • Both AFF A400 controllers are on standby at the LOADER prompt.
  • You have all the appropriate cabling on-hand.
About this task
The following steps are performed on AFF A250 node1.
Steps
  1. Access the advanced privilege level:
    set -privilege advanced
  2. Disable storage failover automatic giveback:
    storage failover modify -node node1 -auto-giveback false
  3. Disable auto-revert of the LIFs across both nodes of the HA pair:
    network interface modify -lif * -auto-revert false
  4. Display the status of all data network LIFs:
    network interface show -role data
  5. Display the status of the cluster management LIFs:
    network interface show -role cluster_mgmt
  6. Migrate all data LIFs from the storage virtual machines hosted on node2:
    network interface migrate -vserver vserver_name -lif lif_name -destination-node node1 -destination-port port_name
    Note This command only migrates non-SAN LIFs. You cannot use it to migrate iSCSI and FCP LIFs.
  7. Display the status of all data LIFs in the cluster:
  8. If any LIFs are down, set the administrative status of the LIFs to up by entering the following command, once for each LIF:
    network interface modify -vserver vserver_name -lif lif_name -status-admin up
  9. Display the status of all data aggregates in the cluster:
    storage aggregate show
  10. Display failover eligibility:
    storage failover show
  11. Migrate the data aggregates on node2 to node1:
    storage aggregate relocation start -aggregate aggregate_name -node node2 -destination node1
  12. Display the status of all data aggregates in the cluster:
  13. Display the status of all data volumes in the cluster:
    volume show
  14. Display the ha status and ownership of epsilon:
    cluster show
  15. Disable cluster ha:
    cluster ha modify -configured false
  16. Display the ha status and ownership of epsilon:
    cluster show
  17. Halt node2:
    halt -node node2 -inhibit-takeover true -ignore-quorum-warnings true
