Verify switchover, healing, and switchback
PDF of this doc site
Upgrade by using ARL
- Use "system controller replace" commands to upgrade controller models in the same chassis
Creating your file...
Your file is ready
You should verify the switchover, healing, and switchback operations of the MetroCluster configuration.
Step
Refer to References to link to the MetroCluster Management and Disaster Recovery content and follow the procedures for negotiated switchover, healing, and switchback.
