Manage authentication keys using the Onboard Key Manager
PDF of this doc site
Upgrade by using ARL
- Use "system controller replace" commands to upgrade controller models in the same chassis
Creating your file...
Your file is ready
You can use the Onboard Key Manager (OKM) to manage authentication keys. If you have the OKM set up, you must record the passphrase and backup material before beginning the upgrade.
Steps
Record the cluster-wide passphrase.
This is the passphrase that was entered when the OKM was configured or updated using the CLI or REST API.
Back up the key-manager information by running the
security key-manager onboard show-backup
command.
