Restore BlueXP backup and recovery configuration data in a dark site
When you use BlueXP backup and recovery in a site with no internet access, known as private mode, the BlueXP backup and recovery configuration data is backed up to the StorageGRID or ONTAP S3 bucket where your backups are being stored. If you have an issue with the BlueXP Connector host system, you can deploy a new Connector and restore the critical BlueXP backup and recovery data.
This procedure applies only to ONTAP volume data. |
When you use BlueXP backup and recovery in a SaaS environment where the BlueXP Connector is deployed at your cloud provider, or on your own host system that has internet access, all the important BlueXP backup and recovery configuration data is backed up and protected in the cloud. If you have an issue with the Connector, just create a new Connector and add your working environments and the backup details are automatically restored.
There are two types of data that are backed up:
BlueXP backup and recovery database - contains a listing of all the volumes, backup files, backup policies, and configuration information.
Indexed Catalog files - contains detailed indexes that are used for Search & Restore functionality that make your searches very quick and efficient when looking for volume data that you want to restore.
This data is backed up once per day at midnight, and a maximum of 7 copies of each file are retained. If the Connector is managing multiple on-premises ONTAP working environments, the BlueXP backup and recovery files will be located in the bucket of the working environment that was activated first.
No volume data is ever included in the BlueXP backup and recovery database or Indexed Catalog files. |
Restore BlueXP backup and recovery data to a new BlueXP Connector
If your on-premises BlueXP Connector has a catastrophic failure, you'll need to install a new Connector, and then restore the BlueXP backup and recovery data to the new Connector.
You'll need to perform the following tasks to return your BlueXP backup and recovery system to a working state:
Install a new BlueXP Connector
Restore the BlueXP backup and recovery database
Restore the Indexed Catalog files
Rediscover all of your on-prem ONTAP systems and StorageGRID systems to the BlueXP UI
Once you verify that your system is back in a working order, we recommend that you create new backup files.
You'll need to access the most recent database and index backups from the StorageGRID or ONTAP S3 bucket where your backup files are being stored:
BlueXP backup and recovery MySQL database file
This file is located in the following location in the bucket
netapp-backup-<GUID>/mysql_backup/
, and it is namedCBS_DB_Backup_<day>_<month>_<year>.sql
Indexed Catalog backup zip file
netapp-backup-<GUID>/catalog_backup/
, and it is namedIndexed_Catalog_DB_Backup_<db_name>_<day>_<month>_<year>.zip
Install a new Connector on a new on-premises Linux host
When installing a new BlueXP Connector, make sure you download the same release of software as you had installed on the original Connector. Periodic changes to the BlueXP backup and recovery database structure may make newer software releases incompatible with the original database backups. You can upgrade the Connector software to the most current version after restoring the Backup database.
Install the BlueXP Connector on a new on-premises Linux host
Log into BlueXP using the admin user credentials that you just created.
Copy the MySQL backup from the backup location to the new Connector host. We'll use the example file name "CBS_DB_Backup_23_05_2023.sql" below.
Copy the backup into the MySQL docker container using one of the following commands, depending on whether you are using a Docker or Podman container:
docker cp CBS_DB_Backup_23_05_2023.sql ds_mysql_1:/.
podman cp CBS_DB_Backup_23_05_2023.sql ds_mysql_1:/.
Enter the MySQL container shell using one of the following commands, depending on whether you are using a Docker or Podman container:
docker exec -it ds_mysql_1 sh
podman exec -it ds_mysql_1 sh
In the container shell, deploy the "env".
You'll need the MySQL DB password, so copy the value of the key "MYSQL_ROOT_PASSWORD".
Restore the BlueXP backup and recovery MySQL DB using the following command:
mysql -u root -p cloud_backup < CBS_DB_Backup_23_05_2023.sql
Verify that the BlueXP backup and recovery MySQL DB has been restored correctly using the following SQL commands:
Enter the password.
mysql> show tables; mysql> select * from volume;
Check if the volumes that are shown are the same as those that existed in your original environment.
Copy the Indexed Catalog backup zip file (we'll use the example file name "Indexed_Catalog_DB_Backup_catalogdb1_23_05_2023.zip") from the backup location to the new Connector host in the "/opt/application/netapp/cbs" folder.
Unzip the "Indexed_Catalog_DB_Backup_catalogdb1_23_05_2023.zip" file using the following command:
unzip Indexed_Catalog_DB_Backup_catalogdb1_23_05_2023.zip -d catalogdb1
Run the ls command to make sure that the folder "catalogdb1" has been created with the subfolders "changes" and "snapshots" underneath.
Discover your ONTAP clusters and StorageGRID systems
Discover all the on-prem ONTAP working environments that were available in your previous environment. This includes the ONTAP system you have used as an S3 server.
Set up the StorageGRID environment details
Add the details of the StorageGRID system associated with your ONTAP working environments as they were set up on the original Connector setup using the BlueXP APIs.
The following information applies to private mode installations starting from BlueXP 3.9.xx. For older versions, use the following procedure: DarkSite Cloud Backup: MySQL and Indexed Catalog Backup and Restore.
You'll need to perform these steps for each system that is backing up data to StorageGRID.
Extract the authorization token using the following oauth/token API.
curl 'http://10.193.192.202/oauth/token' -X POST -H 'Accept: application/json' -H 'Accept-Language: en-US,en;q=0.5' -H 'Accept-Encoding: gzip, deflate' -H 'Content-Type: application/json' -d '{"username":"admin@netapp.com","password":"Netapp@123","grant_type":"password"} > '
While the IP address, username, and passwords are custom values, the account name is not. The account name is always "account-DARKSITE1". Also, the username must use an email-formatted name.
This API will return a response like the following. You can retrieve the authorization token as shown below.
{"expires_in":21600,"access_token":"eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6IjJlMGFiZjRiIn0eyJzdWIiOiJvY2NtYXV0aHwxIiwiYXVkIjpbImh0dHBzOi8vYXBpLmNsb3VkLm5ldGFwcC5jb20iXSwiaHR0cDovL2Nsb3VkLm5ldGFwcC5jb20vZnVsbF9uYW1lIjoiYWRtaW4iLCJodHRwOi8vY2xvdWQubmV0YXBwLmNvbS9lbWFpbCI6ImFkbWluQG5ldGFwcC5jb20iLCJzY29wZSI6Im9wZW5pZCBwcm9maWxlIiwiaWF0IjoxNjcyNzM2MDIzLCJleHAiOjE2NzI3NTc2MjMsImlzcyI6Imh0dHA6Ly9vY2NtYXV0aDo4NDIwLyJ9CJtRpRDY23PokyLg1if67bmgnMcYxdCvBOY-ZUYWzhrWbbY_hqUH4T-114v_pNDsPyNDyWqHaKizThdjjHYHxm56vTz_Vdn4NqjaBDPwN9KAnC6Z88WA1cJ4WRQqj5ykODNDmrv5At_f9HHp0-xVMyHqywZ4nNFalMvAh4xESc5jfoKOZc-IOQdWm4F4LHpMzs4qFzCYthTuSKLYtqSTUrZB81-o-ipvrOqSo1iwIeHXZJJV-UsWun9daNgiYd_wX-4WWJViGEnDzzwOKfUoUoe1Fg3ch--7JFkFl-rrXDOjk1sUMumN3WHV9usp1PgBE5HAcJPrEBm0ValSZcUbiA"}
Extract the Working Environment ID and the X-Agent-Id using the tenancy/external/resource API.
curl -X GET http://10.193.192.202/tenancy/external/resource?account=account-DARKSITE1 -H 'accept: application/json' -H 'authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6IjJlMGFiZjRiIn0eyJzdWIiOiJvY2NtYXV0aHwxIiwiYXVkIjpbImh0dHBzOi8vYXBpLmNsb3VkLm5ldGFwcC5jb20iXSwiaHR0cDovL2Nsb3VkLm5ldGFwcC5jb20vZnVsbF9uYW1lIjoiYWRtaW4iLCJodHRwOi8vY2xvdWQubmV0YXBwLmNvbS9lbWFpbCI6ImFkbWluQG5ldGFwcC5jb20iLCJzY29wZSI6Im9wZW5pZCBwcm9maWxlIiwiaWF0IjoxNjcyNzIyNzEzLCJleHAiOjE2NzI3NDQzMTMsImlzcyI6Imh0dHA6Ly9vY2NtYXV0aDo4NDIwLyJ9X_cQF8xttD0-S7sU2uph2cdu_kN-fLWpdJJX98HODwPpVUitLcxV28_sQhuopjWobozPelNISf7KvMqcoXc5kLDyX-yE0fH9gr4XgkdswjWcNvw2rRkFzjHpWrETgfqAMkZcAukV4DHuxogHWh6-DggB1NgPZT8A_szHinud5W0HJ9c4AaT0zC-sp81GaqMahPf0KcFVyjbBL4krOewgKHGFo_7ma_4mF39B1LCj7Vc2XvUd0wCaJvDMjwp19-KbZqmmBX9vDnYp7SSxC1hHJRDStcFgJLdJHtowweNH2829KsjEGBTTcBdO8SvIDtctNH_GAxwSgMT3zUfwaOimPw'
This API will return a response like the following. The value under the "resourceIdentifier" denotes the WorkingEnvironment Id and the value under "agentId" denotes x-agent-id.
Update the BlueXP backup and recovery database with the details of the StorageGRID system associated with the working environments. Make sure to enter the Fully Qualified Domain Name of the StorageGRID, as well as the Access-Key and Storage-Key as shown below:
curl -X POST 'http://10.193.192.202/account/account-DARKSITE1/providers/cloudmanager_cbs/api/v1/sg/credentials/working-environment/OnPremWorkingEnvironment-pMtZND0M' \ > --header 'authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6IjJlMGFiZjRiIn0eyJzdWIiOiJvY2NtYXV0aHwxIiwiYXVkIjpbImh0dHBzOi8vYXBpLmNsb3VkLm5ldGFwcC5jb20iXSwiaHR0cDovL2Nsb3VkLm5ldGFwcC5jb20vZnVsbF9uYW1lIjoiYWRtaW4iLCJodHRwOi8vY2xvdWQubmV0YXBwLmNvbS9lbWFpbCI6ImFkbWluQG5ldGFwcC5jb20iLCJzY29wZSI6Im9wZW5pZCBwcm9maWxlIiwiaWF0IjoxNjcyNzIyNzEzLCJleHAiOjE2NzI3NDQzMTMsImlzcyI6Imh0dHA6Ly9vY2NtYXV0aDo4NDIwLyJ9X_cQF8xttD0-S7sU2uph2cdu_kN-fLWpdJJX98HODwPpVUitLcxV28_sQhuopjWobozPelNISf7KvMqcoXc5kLDyX-yE0fH9gr4XgkdswjWcNvw2rRkFzjHpWrETgfqAMkZcAukV4DHuxogHWh6-DggB1NgPZT8A_szHinud5W0HJ9c4AaT0zC-sp81GaqMahPf0KcFVyjbBL4krOewgKHGFo_7ma_4mF39B1LCj7Vc2XvUd0wCaJvDMjwp19-KbZqmmBX9vDnYp7SSxC1hHJRDStcFgJLdJHtowweNH2829KsjEGBTTcBdO8SvIDtctNH_GAxwSgMT3zUfwaOimPw' \ > --header 'x-agent-id: vB_1xShPpBtUosjD7wfBlLIhqDgIPA0wclients' \ > -d ' > { "storage-server" : "sr630ip15.rtp.eng.netapp.com:10443", "access-key": "2ZMYOAVAS5E70MCNH9", "secret-password": "uk/6ikd4LjlXQOFnzSzP/T0zR4ZQlG0w1xgWsB" }'
Verify BlueXP backup and recovery settings
Select each ONTAP working environment and click View Backups next to the Backup and recovery service in the right-panel.
You should be able to see all the backups that have been created for your volumes.
From the Restore Dashboard, under the Search & Restore section, click Indexing Settings.
Make sure that the working environments which had Indexed Cataloging enabled previously remain enabled.
From the Search & Restore page, run a few catalog searches to confirm that the Indexed Catalog restore has been completed successfully.
