Quick start for the Monitoring service
Complete a few steps to start monitoring Cloud Volumes ONTAP performance.
Quick start
Get started quickly by following these steps or scroll down to the remaining sections for full details.
You need a Cloud Volumes ONTAP system running in AWS or Azure.
For AWS, you need a Connector running version 3.8.4 or later.
For Azure, you need a Connector running version 3.9.3 or later.
New working environments: Be sure to keep Monitoring enabled when you create the working environment (it’s enabled by default).
Existing working environments: Select a working environment and click Start Monitoring.
Click Monitoring and view performance data for your volumes.
