NetApp Backup and Recovery
NetApp Backup and Recovery requirements
Contributors netapp-mwallis netapp-yvonneo
Verify that your NetApp Console and operational environment meet the requirements for protecting your ONTAP volume, database, virtual machine, and Kubernetes workloads with NetApp Backup and Recovery.
Prepare to use NetApp Backup and Recovery
You access NetApp Backup and Recovery through NetApp Console. Perform these tasks to prepare the Console for Backup and Recovery, depending on whether you are using NetApp Console or NetApp Console local deployment.
Prepare to use Backup and Recovery on NetApp Console
To prepare NetApp Console for Backup and Recovery, you must:
  • Complete initial setup
  • Add a Console agent
  • Add at least one storage system
  • Enable Backup and Recovery
  • Configure a Console organization and user roles
You need the Organization admin or Super admin role in NetApp Console to complete this preparation.
To learn more about NetApp Console, refer to NetApp Console for unified storage management.
Complete initial NetApp Console setup
Complete the initial setup for NetApp Console if you haven't already.
Deploy a Console agent
A Console agent is a lightweight software component that you install in your network to connect your storage infrastructure to NetApp Console. It enables advanced storage orchestration, data services, and secure cloud integration.
Add a storage system
Before you can protect workloads in Backup and Recovery, you need to add an ONTAP storage system to the Console.
Enable Backup and Recovery in NetApp Console
You can enable Backup and Recovery on a system when you add it, or at a later time.
Configure an organization and user roles
Learn about organizations, projects, fleets, and user roles, then configure users with the appropriate permissions needed to perform their tasks.
Refer to Add users to a NetApp Console organization for information about controlling resource access.
Refer to NetApp Backup and Recovery roles in NetApp Console for details about the roles and permissions needed to perform operations in NetApp Backup and Recovery.
Prepare to use Backup and Recovery on NetApp Console local deployment
To prepare to use NetApp Backup and Recovery on NetApp Console local deployment, you must:
  • Complete initial NetApp Console local deployment setup
  • Sign up for preview enrollment
  • Grant access to resources for users
You need the Organization admin or Super admin role in NetApp Console local deployment to complete this preparation.
To learn more about NetApp Console local deployment, refer to Learn about NetApp Console local deployment.
Complete the initial setup for NetApp Console local deployment if you haven't already. Completing initial setup includes adding licenses for data services (including Backup and Recovery).
Sign up for NetApp Backup and Recovery preview enrollment
Sign up for NetApp Backup and Recovery preview on NetApp Console local deployment:
Enable Backup and Recovery in NetApp Console local deployment
Learn about identity and access management, then configure users with the appropriate permissions needed to perform their tasks.
Refer to Get started with identity and access in NetApp Console local deployment for information about identity and access.
Requirements for backups to object storage
To use object storage as backup targets, you need an account with AWS S3, Google Cloud Storage, Azure Blob storage, StorageGRID, or ONTAP and the appropriate access permissions configured.
Requirements for protecting ONTAP volume workloads
To use NetApp Backup and Recovery for ONTAP volume workloads, you need the following prerequisites.
Ensure you have the following before discovering an ONTAP system in Backup and Recovery:
  • Ensure that an ONTAP One License is enabled on the on-premises ONTAP instance.
  • Ensure that the AMQP application is enabled as a Password login method for the ONTAP user you use for discovering ONTAP systems. This enables scheduled backup jobs to appear in the Job Monitor. Refer to the ONTAP documentation for user management instructions.
Some ONTAP features require specific ONTAP versions:
Feature Required ONTAP version
Protect ONTAP volumes
9.8 or later
Protect FlexGroup volumes (Refer to Known limitations with NetApp Backup and Recovery for ONTAP volumes for more information)
9.12.1 or later
Use Microsoft Entra ID authentication for Azure buckets when protecting Cloud Volumes ONTAP
9.16.1 or later
Back up or restore to S3-compatible object storage
9.17.1 or later
Use more than six buckets per system across different cloud providers (up to 100 buckets maximum)
9.19.1 or later
For information about supported features, volume types, backup and restore destinations, and more, refer to Protect ONTAP volumes workloads with NetApp Backup and Recovery.
Requirements for protecting Microsoft SQL Server workloads
To use NetApp Backup and Recovery for Microsoft SQL Server workloads, you need the following host system, space, and sizing prerequisites.
Note ONTAP 9.19.1 or later is required to support more than six buckets per system across different cloud providers (up to 100 buckets maximum).
Software and hardware requirements
Item Requirements
Operating systems
Microsoft Windows
For the latest information about supported versions, see the NetApp Interoperability Matrix Tool.
Microsoft SQL Server versions
Versions 2012 and later are supported for VMware Virtual Machine File System (VMFS) and VMware Virtual Machine Disk (VMDK) on NFS.
SnapCenter Server version
SnapCenter Server version 5.0 or later is required to import your existing data from SnapCenter into NetApp Backup and Recovery.
Note If you already have SnapCenter, first check to be sure you've met the prerequisites before importing from SnapCenter. See Prerequisites for importing resources from SnapCenter.
Minimum RAM for the plug-in on the SQL Server host
1 GB
Minimum install and log space for the plug-in on the SQL Server host
5 GB
Allocate sufficient disk space and monitor the storage consumption by the logs folder. The log space required varies depending on the number of backups performed and the frequency of data protection operations. If there isn't enough space, logs aren't created for the operations.
Required software packages
  • ASP.NET Core Runtime 10.0.10 Hosting Bundle
  • PowerShell 7.6.4
Supported storage types
Database host Supported storage
Physical server
  • LUNs presented over Fibre Channel
  • LUNs presented over iSCSI
VMware VM
  • iSCSI LUNs connected directly to the guest system by the iSCSI initiator
  • Virtual Machine File Systems (VMFS)
  • NFS datastores
Hyper-V VM
Note Protecting databases stored in pass-through disks or VHD/VHDX files that are provisioned on NetApp storage is not supported.
Required permissions for Microsoft SQL Server host discovery
When you discover an SQL Server host, NetApp Backup and Recovery installs the NetApp SnapCenter Plug-in for Microsoft SQL Server on the host. You can also choose to install the plug-in manually instead. If you choose automatic installation, the host credentials you provide during discovery must have the following memberships and permissions so that Backup and Recovery can install the plug-in:
  • Membership in the Microsoft SQL Server instance's sysadmin fixed server-level role
  • Membership in the Windows local Administrator group
  • Permission to log in to the host
Requirements for protecting VMware workloads
You need specific requirements to discover and protect your VMware workloads.
Software support
Requirement Supported
Datastore types
NFSv3, NFSv4.1, and VMFS
VMware ESXi Server versions
7.0U1 and above
VMware vCenter vSphere versions
7.0U1 and above
VMware Tools
VMware Tools is required when using the file and folder restore feature and VM-consistent backups. To make sure the VMware Tools version matches your version of ESXi Server, refer to the VMware version mapping information.
IP address types
IPv4, IPv6
VMware TLS versions
1.2, 1.3
Connected storage
  • ONTAP 9.13.1 or later (ONTAP 9.19.1 or later is required to support more than six buckets per system across different cloud providers; up to 100 buckets maximum)
  • ASA r2 SAN-only systems (ONTAP 9.17.1 or later required)
  • Amazon FSx for NetApp ONTAP storage systems running version 9.13.1 or later
  • Google Cloud NetApp Volumes (ONTAP-mode and Flex Unified service level)
Connection and port requirements for protecting VMware workloads
Type of port Pre-configured port
VMware ESXi Server port
443 (HTTPS), bidirectional. The file and folder restore feature uses this port.
Storage cluster or storage VM port
  • 443 (HTTPS), bidirectional.
  • 80 (HTTP), bidirectional. This port is used for communication between the virtual appliance and the storage VM or the cluster containing the storage VM.
Role-based access control (RBAC) requirements for protecting VMware workloads
Your Console user account needs to have the Backup and Recovery super admin role to work with VMware workloads.
For more information about Backup and Recovery roles, refer to Backup and Recovery roles in NetApp Console.
Requirements for protecting KVM workloads
You need specific requirements to discover and protect KVM virtual machines.
  • A modern Linux distribution running kernel version 5.14.0-503.22.1.el9_5.x86_64 (longterm) or later
  • Your KVM hosts and VMs must be managed by a management platform. NetApp Backup and Recovery supports the following management platforms:
    • Apache CloudStack 4.22.0.0
  • Ensure that inbound network traffic to port 22 is allowed from the Console agent to the KVM host
  • QEMU Guest Agent version 9.0.0 or later
  • libvirt version 10.5.0 or later
Note To ensure that KVM workload restores complete successfully, make sure that the Enable VM-consistent snapshot setting is active in the protection policy you use for KVM backups.
Note
To enable protection of KVM VMs administered by non-root users, use the following steps:
  1. Mount the volume as type NFS3 to avoid the use of the nobody user and group.
  2. Use the following command to add a non-root user to the qemu group while preserving their existing groups:
    usermod -aG qemu <non-root-user>
  3. Use the following command to grant ownership of the mount path to the qemu user and group and change permissions for the mount path:
    chown -R qemu:qemu <kvm_vm_mount_path> & chmod 771 <kvm_vm_mount_path>
  4. Delete the existing NetApp_SnapCenter_Backups directory if present.
Requirements for protecting Oracle Database workloads
Ensure your environment meets specific requirements to discover and protect Oracle Database resources.
Deployment topology
  • Standalone (NFS, SAN, ASM SAN)
  • RAC over ASM (VMDK on VMFS)
Oracle Database versions
  • Oracle Database 19c
  • Oracle Database 21c
  • Oracle AI Database 26ai
Database storage
Must be deployed on NetApp ONTAP (primary or secondary)
Host OS
  • Red Hat Enterprise Linux 8
  • Red Hat Enterprise Linux 9
Object storage (backup targets)
  • Azure Blob storage
  • AWS S3
  • NetApp StorageGRID
  • ONTAP S3
Required permissions for Oracle Database host discovery
When you discover an Oracle Database host, NetApp Backup and Recovery installs the NetApp Oracle Database plug-in on the host using password-based SSH. You can also choose to install the plug-in manually instead. You need specific permissions for plug-in installation.
Requirements for plug-in installation
The host credentials you provide during discovery must have the following permissions so that Backup and Recovery can install the NetApp Oracle Database plug-in:
  • The ability to log in to the host using SSH.
  • Root permissions, or sudo access for a non-root user.
    • To grant sudo access during host discovery, select non-root credentials in the Host registration section, then select Configure sudoers and follow the instructions. Root credentials do not need this step. This step is not required for manual installation.
  • Execute permission for the Java JVM.
  • SYSDBA privileges are required for the Oracle database user.
Requirements for protecting Kubernetes applications
You need specific requirements to discover Kubernetes resources and protect your Kubernetes applications.
Note NetApp strongly recommends assigning a static IP address to the Console agent you use for Kubernetes workloads to avoid issues if the agent IP address changes.
  • A primary ONTAP system (ASA r2 systems are not supported)
  • NetApp Trident 25.06 to 26.06
  • NetApp Trident Protect 26.08 or later (installed on the Kubernetes cluster during discovery)
  • A Kubernetes cluster - Supported Kubernetes distributions and versions include those supported by Trident Protect.
    • Make sure that TCP port 443 is unfiltered in the outbound direction between the Kubernetes cluster, the Trident Protect Connector, and the Trident Protect proxy.
  • To restore files and folders from VM-based applications, SSH is required. Verify that the SSH service is enabled on Linux destination hosts and that an OpenSSH server is installed and enabled on Windows destination hosts.
Requirements for protecting Hyper-V workloads
Ensure your Hyper-V instance meets specific requirements to discover and protect virtual machines.
Software requirements for the Hyper-V Windows Server host
Microsoft Hyper-V
2019, 2022, and 2025 editions
PowerShell
7.6.4 or later
If non-administrator users will be protecting Hyper-V VMs, ensure the users have the following permissions
  • Member of the local administrators group
  • Part of the "Log on as service" local security policy
Ensure that two-way HTTPS traffic is allowed for the following ports in the Windows Firewall settings
  • TCP 8144 (NetApp Plugin for Hyper-V)
  • TCP 8145 (NetApp Plugin for Windows)
Connected storage
  • SMB shares
  • SAN storage connected via iSCSI or Fibre Channel
Hardware requirements for the Hyper-V host
  • Standalone hosts and failover cluster configurations are supported
  • 1GB RAM minimum for the NetApp Hyper-V plug-in on the Hyper-V host
  • 5GB minimum installation and log space for the plug-in on the Hyper-V Host
    Note Ensure that you allocate enough disk space on the Hyper-V host for the logs folder and regularly monitor its usage. The required space depends on how often backups and data protection operations occur. If there isn't enough space, logs aren't generated.
NetApp ONTAP configuration requirements
  • A primary ONTAP system (ONTAP 9.14.1 or later - ONTAP 9.19.1 or later is required to support more than six buckets per system across different cloud providers; up to 100 buckets maximum)
  • For Hyper-V deployments using SMB shares to store virtual machine data, ensure that the continuous availability share property is enabled on the ONTAP system. Refer to the ONTAP documentation for instructions.
